Decided to take a break from construction and build a third workbench. I had previously built two 3 ft. x 5 ft. benches that I had intended to use during the construction. However during the initial work on the empennage and having filled two organizers with the small parts and having the plans and all the other things (tools, etc.) required for the build has basically made one of the two original tables not available for actual build work. I now have three identical benches and will plan to use two of them to do the building on. With a total length of 10 ft. when pushed and locked together this should work well. It has taken up more of the garage space but I believe will pay benefits in the future. With the bottom shelve it also provides additional space for storage of larger parts.
