Johns Web Site
Date:  10-28-2020
Number of Hours:  4.00
Manual Reference:  22iS/U-03,04
Brief Description:  F-01201B-1 and F-01217-L & R
Completed steps 4-8 page 22iS/U-03
Step 4: Dimpled #30 the aft holes in F-01201B-1 that correspond to F-01257-1 per Figure 3.
Step 5: Dimpled #40 the called out nutplate rivet holes in F-01201B-1.
Step 6: Clecoed the center F-01257-1 to F-01201B-1. Used a step drill to enlarge the fwd #30
hole in the F-01257-1 up to the diameter of the corresponding hole in F-01201B-1.
Step 7: Riveted the two nutplates just outboard of the center F-01257-1.
Step 8: Riveted F-01257-1 to F-01201B-1 along with the nutplates where applicable. Did NOT
RIVET the aft most nor the fwd most holes.
Completed steps 1-5 page 22iS/U-04 for both left and right sides
Step 1: Machine countersunk #40 the nutplate attach holes in F-01217-L per Figure 1.
Step 2: Machine countersunk #30 the fwd flange of F-01217-L, with WD-1204 in place, to receive the dimpled firewall.
Step 3: Dimpled #30 the hole in F-01217-L and F-12131-L.
Step 4: Used a step drill to enlarge the fwd #30 hole in the web of F-01217-L (aft hole in F-01217-R) to 5/8 in.
Completed step 8 page 21iS/U-24
Step 8: Cleaned the region of the aft center section bulkhead in which the F-01204N Fuel Tank Pad will be placed. See Figure 2 and Page 21iS/U-01. Removed the adhesive backing from F-01204N and positioned it horizontally centered (side-to-side), and vertically contacting the edge of the F-01224-L-1 and -R-1 Baggage Floor flanges as shown. Pressed firmly for a good bond.
