Johns Web Site
Date:  1-19-2013
Number of Hours:  6.50
Manual Reference:  10-03, 10-04
Brief Description:  Fuselage Frames, Bulkhead, Tailskid Bracket
Completed step 6 page 10-04 – drilled out 8 nutplate screw holes to #12. Completed step 2 page 10-03 – removed tabs from F-1211B bulkhead doubler and deburred edges and holes on part. Completed step 3 page 10-03 – machine countersink holes in F-1211B bulkhead doubler as called out in Figure 2. Completed step 4 – separated the F-1211D attach brackets and deburred edges. Completed step 5 – page 10-03 separated F-1284 L&R shear clips and deburred edges. Completed step 6 – separated the F-1211C L&R and marked and deburred edges. Completed step 7 page 10-03 – marked then separated F-1283, A,B, C. Deburred edges and readied for primer. Completed step 2 page 10-04 fluted the F-1211A fuse bulkhead – cleaned up edges on part and readied for primer. Completed step 1 page 10-03 – Fabircated the F-1211G tail skid bracket per Figure 1. Completed step 3 page 10-04 – clecoed F-1211B bulkhead doubler to the F-1211A fuselage bulkhead per Figure 2. Completed step 4 page 10-04 – clecoed tailskid bracket to F-1211A fuselage bulkhead per Figure 2 – added additional clamping. Completed step 5 – match drilled #30 holes on F-1211B bulkhead doubler into F-1211G tailskid bracket then removed bracket and deburred the holes. Completed step 6 page 10-04 – final drilled #12 the nutplate screw holes as called out in Figure 2. Primed all frames and bulkheads including all attach brackets, tailskid bracket and misc items ready for prime.
Tailskid Bracket
Tailskid Bracket
Tailskid Bracket
Tailskid Bracket
Fluting of Bulkhead
Fluting of Bulkhead
