Johns Web Site
Date:  4-2-2017
Number of Hours:  3.00
Manual Reference:  27-03
Brief Description:  Completed rudder/brake pedal assembly
Completed rework of the one WD-1209 outboard brake pedal with the new pedal and torques tube per steps 1-3 page 27-03. Completed step 5 - Greased the WD-1211-R & -L Brake Pedal Torque Tubes then slid them into the WD-1206 Rudder Pedals. Completed step 6 - Secured the WD-1209 Brake Pedals and F-1290 Pedal Blocks to the WD-1211 Brake Pedal Torque Tubes using the hardware called out in Figure 3. Did not need to file away any portion of the pedal blocks since there was no interference with the welds on the brake pedals or WD-1206 Rudder Pedals. Completed step 7 - Attached the master cylinders to the WD-1206 Rudder Pedals and WD-1211-L & -R Brake Pedal Torque Tubes using the hardware called out in Figure 3. Will leave steps 8 and 9 for later when peal assembly is installed in fuselage. Leaving out for now to have extra work space.
