Brief Description: Sealed Canopy Ribs - Installed Fuel Tank
Completed step 8 page 29iS/U-08
Step 8: Seal the lower outboard edges of the Canopy Rib Assemblies with fuel tank sealant.
Needed to install fuel tank again for completion of fuel lines to and from tank. Determined the I was not able again to install the spacer washer NAS1149F0332P on the one side of the tank per Figure 2 page 26iS/U-06. Took pictures of the mounting on both sides and will send to Vans to see if it is acceptable to not have the washer installed.
