Brief Description: Installation of PAnel BAse and Canopy Ribs
Completed step 5 page 29iS/U-07
Step 5: Riveted tje F-01202C-L&R and both WD-1204 to the web of the F-01202B-1 per Figure 2. Put the manufactured heads on the bottom face of the F-01202C-L&R
Completed steps 1-7 page 29iS/U-08
Step 1: Clecoed the F-01202B-1 to the F-01201A-1. Verified that the aft edge of the F-01202B-1 abuts the forward edges of the F-1234-L & -R and that the left and right edges of the F-01202B-1 align with the fuselage side skins. Step 2: Match-Drilled #30 the holes common to the F-01202B-1 and F-1255-L & -R as shown. Removed the F-01202B-1 Step 3: Clecoed the Canopy Rib Assemblies to the F-01202B-1 and match-drilled #30 the holes from the F-01202B-1 into both F-1202Y. Removed the Canopy Rib Assemblies. Step 4: For the forward four holes in the left and right edges of the F-01202B-1, riveted the F-01202B-1 to the F-1255-L & -R as shown. Step 5: Riveted the Canopy Rib Assemblies and both F-12132 to the F-01202B-1 and F-1255-L & -R. The F-12132 were attached to the bottom surface of the F-01202B-1. Step 6: Riveted the F-01202B-1 to the F-1255-L & -R. Step 7: Riveted the F-01202B-1 and Canopy Rib Assemblies to the F-01201A-1. Riveted the nutplates common to the F-01202B-1 and F-01201A-1.
