Step 5: Riveted nutplates around the access holes of F-01224-R-1 & -L-1. Step 6: Riveted F-01224-L-1 & -R-1 to F-01204D-1 and F-01204F-L-1 & -R-1 using the rivets called out in Figure 2. Use two thin flush sets in a hand squeezer and apply tape to the squeezer to prevent scratching the baggage floors.
Completed steps 1-3 and 6 page 21iS/U-03 Step 1: Separated F-12102AB by removing the hatched areas shown in Figure 1.
Step 2: Dimpled the #30 and #40 holes in the F-01221-R-1 that correspond to the dimpled holes in F-01224-R-1 perFigure 2. Taped over the holes attaching F-01241 to F-01224-R-1 and to the baggage ribs per Page 21iS/U-02, Figure 2. Step 3: Riveted F-01221-R-1, F-01222-R-1, and F-01223-R-1 to F-01204D-1 and F-01224-R-1 using the rivets called out in Figure 2. Installed the rivets so the manufactured heads are on F-01204D-1. Noted the flush rivet location in F-01223-R-1, (also applies to F-01223-L-1, though not shown in Figure 2).
