Completed step 8 page 29A-06 - Applied paste wax then Boelube, to the area of the F-1240 Skin that mates with the F-1201H Upper Fwd Fuse Doubler per Detail A. Cleaned doubler surface before applying sealant where indicated in Detail A. Applied approx. 1/16 in. bead of Permatex 16BR Black Silicone Adhesive Sealant #81158 per manufacturer's directions along the entire length of the doubler as shown in Detail A. Competed step 9 - Screwed the F-1240 Upper Forward Fuselage Skin to the F-1201A Assembly, F-1270-L and F-1270-R Fuselage Side Skins and F-1202H-L and -1202H-R Canopy Ribs. Screwed the F-1240B Assembly to the upper forward fuselage skin per Figure 4. Completed step 10 - Dimpled the nutplates called out in Figure 4 and the rivet locations in the F-1202D-L and F-1202D-R Panel Attach Strips. Riveted the nutplates to the panel attach strips per Figure 4.
