Completed step 6 – page 29A=06 - Carefully curved the forward edge of the F-1240 Upper Forward Fuselage Skin down by hand. The upper forward fuselage skin was laid flat on a table and the fwd edge of the skin carefully worked over the edge, taking care not to crease the skin. The upper forward fuselage skin is curved enough that the forward edge presses against the F-1201H Upper Forward Fuselage Doubler when installed per Figure 3. Completed step 7 - Final-Reamed #19 then dimpled the holes in the F-1240 Upper Forward Fuselage Skin as shown in Figure 3. Also dimpled the rivet holes for the AN46AD3 rivets as shown in Figure 3.
