Completed step 1 page 29A-06 - Dimpled the three holes in each F-1201E-L and -R Oil Tank Side Bracket that will receive flush fasteners as called out in Figure 1. Machine countersunk the corresponding holes in the F-1201Q-L and -R Battery Mount Angles. Completed step 2 - Riveted the F-1201E-L and -R Oil Tank Side Brackets to the F-1201A Firewall Upper. Riveted the F-1201F Battery Mount Brace to the firewall upper per Figure 1. Completed step 3 - Riveted the F-1201F Battery Mount Brace, F-1201Q-L & -R Battery Mount Angles and F-1201G Oil Reservoir Brace to the F-1201E-L and -R Oil Tank Side Brackets per Figure 1.
UPDATE 9/5/17 Mark Johnson notice my picture of the oil tank brackets and let me know that I had installed the battery brackets upside down! Thanks Mark for noticing that on my log. I remember having them fit up correctly and checking that the nutplate was to the firewall side but apparently when I took it apart to do the final rivets I got the two pieces mixed up and put them on upside down! Looks like more practice in removing the LP4 and CS rivets. Thanks again Mark for the catch
