Johns Web Site
Date:  8-26-2017
Number of Hours:  3.00
Manual Reference:  29A-05
Brief Description:  Panel Base to Longerons & Engine Mounts
Completed step 6 – page 29A-05. Clecedo the F-1202B Panel Base to the F-1201A Firewall Upper. Checked that the aft edge of the panel base abuts the forward edge of the F-1234-L and -R Canopy Decks and that the left and right edges are parallel to the F-1255-L & -R Longerons then match-drilled #30 the holes common between the panel base and the longerons. Removed the panel base and deburred the longerons per Figure 3. Completed step 7 - Clecoed the F-1202H-L & -R Canopy Ribs to the F-1202B Panel Base and match-drill #30 the holes in the panel base to the F-1202Y Strut Attach Angles. Removed and deburred. Completed step 8 - Final-Drilled #30 all rivet holes in the WD-1204 Engine Mount Brackets then riveted them to the web of the F-1202B Panel Base using rivets specified in Figure 3. Completed step 9 – Installed 2 - SB750-10 Snap Bushings as shown in Figure 3.
