Brief Description: Installed arm rests and trial fit of side skins
Completed step 5 page 23-04 - Match-Drilled #30 forward tabs of the F-1248-L and -R Arm Rests to the F-1202E-L and -R Bulkhead Side Channels. Match-Drilled #30 the aft tabs of the arm rests to the F-1204C-L and -R Fwd Bulkhead Sides. Deburred the bulkhead side channels and fwd bulkhead sides. Completed step 6 - Riveted the F-1248B Fuselage Pin Latch to both the F-1248-L & -R Arm Rests as shown in Figure 3. Completed step 7 - Riveted the F-1248-L and -R Arm Rests to the F-1202E-L and -R Bulkhead Side Channels. Riveted the arm rests to the F-1204C-L and -R Fwd Bulkhead Sides. Riveted the arm rests to the F-1203H-L and -R Arm Rest Brackets per Figure 3. Completed step 8 - : Inserted the F-1234-L and -R Canopy Decks and F-1255-L and -R Longerons (should still be clecoed together as an assembly) into the fuselage skeleton. Clecoed the canopy decks to the upper tab in the F-1203G-L and -R Bulkhead Side Channels per Figure 3. Prepped the F-1202L gussets per step 1 page 23-06. Per step 2 - Clecoed the F-1270-L & -R Fuselage Side Skins (double check left and right), and the F-1270A and F-1270D Side Skin Doublers to the fuselage skeleton. Aligned the aft edge of the F-1234-L & -R Canopy Decks with the forward edge of the F-1205B Roll Bar Attach Plates. Aligned the vertex of the F-1255-L & -R Longeron with the upper edge of the fuselage side skin. Clamped the longeron to the fuselage side skin. Aligned the outboard edge of the F-1205B Roll Bar Attach Plates with the vertex of the longeron. Clamped the roll bar attach plates to the longerons
