Brief Description: Right Wing Tip Marker LIght Extension
Completed step 1 page 40-08 for W-1222-R extension. Completed step 2 – fit the W-1222-R extension to wing tip then drilled the 2 forward and 2 aft holes in the upper flange into W-1204E-R forward wing tip rib. Drilled #30 all hole locations into lower flange of extension and W-1204D-R wing tip closeout. Match drilled #30 the other three holes into extension for the three existing holes in wing tip.
