Completed step 1 page 15-07 – clecoed then riveted 8 – W-1208-L aft trimmed nose ribs to the W-1206-R rear spar. Completed step 2 – clecoed then riveted 4 – W-1208-L forward and aft trimmed nose ribs to the W-1206-R rear spar. Completed step 3 – clecoed then riveted forward and aft trimmed W-1208-R nose rib to W-1206-R rear spar. Completed step 4 – clecoed then riveted forward and aft trimmed W-1208-L nose rib with nutplate to W-1206-R rear spar. Completed step 5 – clecoed then riveted the right sub spar assembly to forward flanges of the W-1208-L and W-1208-R nose ribs per Figure 1. Completed step 6 – inserted the SB375-4 snap bushings into the W-1209 nose ribs. Completed step 1 page 16-04 – attached ES-00081 standoffs to W-1208 nose ribs per Figure 1. Completed step 3 page 16-04 – installed ring terminal end of WH-B216 terminal ground wire to W-1208 nose rib nutplate with hardware per Figure 2.
