Brief Description: Instaal left wing Nav/Psotopn/Strobe Light
Completed step 1 page 40-06 – trimmed W-1222-L fiberglass extension. Completed step 2 – fit the W-12222-L extension to wing tip. Drilled forward two and aft two holes #30 into the W-1204E-L forward wing tip rib. Match drilled through holes existing in wing tip into the W-1222-L extension. Completed step 1 page 40-09 – aligned the LN-200 wing tip Nav/Position/Strobel light set mount bracket – match drilled #27 the through mounting holes. Completed step 2 – installed slot for Molex connector as shown in Figure 1.
