Brief Description: Flipped wing and clecoed leading edge skins
Flipped wing over so top side is up. Carefully worked to Cleco the wrap around skins for the inboard, mid, and outboard skins. It took some finesse to get the skins to line up but working from the leading edge eventually got everything to line up properly. Noted the area to not rivet so the remainder of the top skins can be inserted.
