Completed step 8 page 07-02. Deburred spar caps, drilled holes and prepared R-1202. Completed step 9 – final drilled holes in WD-1205 rudder horn. Completed step 10 – Clecoed R-1204 spar caps and R-1205 hinge brackets and WD-1205 rudder horn to R-1202 spar per plans for fit check. Will take apart to prime parts when temperature permits. Completed step 4 page 07-03 – removed forward flange from one R-1203 main rib to make R-1203A part. Prepared R-1203 ribs and for priming. Smoothed edges and rounded sharp corners on ribs.
