MARTIN'S WEB SITE
Date:  12-9-2009
Number of Hours:  3.00
Manual Reference:  HKS Install
Brief Description:  Throttle, Exhaust, Oil, Starter
Install aluminum and brass 1:2 throttle cable splitter and adjust cable tensioner for correct throw of throttle lever in cockpit.
Test fit exhaust pipes, EGT senders (L&R) and muffler. All ok.
Fill sump with 5W-30 Castrol synthetic oil blend and check for leaks. All OK.
Revise starter motor ground connection and begin checking all connections. Add 20A ATC fuse to starter motor 12 V +, and test started motor for operation. OK. Note, Mag voltages need to be checked.
