Brief Description: Exhaust Test Fit and Elecrtrical
Attach exhaust system to engine for test fit.
Dressed and secured all engine ignition wires. Created a ground terminal block for central ground point. Secured all ignition wires. Wire all sender probes to RADC unit except for oil pressure sender which reqquires a resistive type (ordered fron Lockwood).
Applied wire loom.
Tested starter motor by removing plugs and actuating it.
