Horrible stuff! It can be cut, where thin, with scissors, but the rest...using a dremmel with various bits, you end up holding your breath and covered from head to toe with plastic dust.
Not all pieces will fit, due to changes inside this plane, such as installing the fuel header tank. What will fit will go in temporarily, until after the plane flies and there's more time to make other interior panels.
