Hooked up brake lines to each tire, then attempted to fill the brake lilnes with fluid bottom uip, but it didn't work. Called Bobbi, who came over with a proper fill can and filled the lines from the top, This procedure took a long time, with much effort on everyone's part, pumping the brake pedals and making a mess. The brake pedals are no longer soft, but there is still air in the lines.
