Very long day. Drilled holes for engine mount, firewall behind engine mount, removed floor board and rudder pedals and reinstalled after vacuuming metal shards. Attached and reattached engine mount several times to fit and drill holes for bolts. Deburred a lot of firewall holes.
Drilled, greased and installed nose gear strut and tire. Installed main gear struts, assembled Matco brakes on wheels, greased bearings and now plane stands on its gear.
Cut into access panel under rudder area and ran rudder cables, attached rudder hinges.
