Fitted, drilled and attached carbon fiber support pieces to floor board with machine screws and to steel frame with Adel clamp to prevent fuel line vibration. And to each other with Velcro.
Secured fuel shutoff valve and transducer assembly to the support. Bent 3/4" aluminum tubing to fit forward of it to connector through firewall. Also bent tubing aft and secured to exit of electric fuel pump. All fit's great.
