Changed out Rotax supplied fuel pump for new one as per Service Bulletin (SB-912-063UL). Torqued to 133 in/lb and crimped hoses with special tool (borrowed from friend).
Removed prop hub and blades (for now).
Discussed where to locate the gascolator and electric fuel pump. Cut a piece of phenolic board to mount these 2 things.
