Removed banjo fitting under engine and replaced with a straight fitting sent by Rans. Clocked one end of an oil hose in a vise to line up with straight fitting and the oil reservoir. Beautiful fit.
Laid out instrument panel and cut backing plate for throttle, choke and cabin heat cables/knobs. Drilled holes for nut plates and riveted them on the backing plate. Cut knob holes with unibit, works great!
