Attached a quick drain to the bottom of the oil reservoir and safety wired it.
Did an initial fit of the bottom engine cowling: not good. Looks like the cowl is too long and when you pull it aft, engine parts hit the inside cowling as it slopes up towards the prop. Planning to do a lot of body work later....
