Made aluminum backing plates for radiator brackets, since firewall is not sturdy and weight of water might make radiator pull on firewall. Drilled through all mounting bracket holes, including the center of the S-1 tube. Drilled 340 holes only at this time.
Clecos holding radiator on firewall, so available space on firewall is now clear. Can locate sites for coolant fluid and brake reservoir, etc....
