Have spent days and days deciding on best locations for solenoids, transformers, fuse and grounding blocks, RDAC, etc.
Constructed 2 carbon fiber platforms and attached them to the steel frame on both sides of the plane with adell clamps. One holds 2 fuse blocks and the other holds the RDAC. They're out of sight, but easily accessible on the ground or in flight, if needed.
The transformer and capacitor were mounted inside to avoid engine heat. 2 grouding blocks are mounted back to back, one forward and one aft of the firewall.
