Chose location on firewall for parking brake valve, constructed a smaller backing plate (out of carbon fiber) than the one supplied by Rans (aluminum) and drilled through the firewall/blanket. Built an offset for the boden cable wire to the main gear brakes using an aluminum tube spacer. Attached all to the interior firewall on copilot side.
