Cauterized exit holes for pitch trim cable. Drilled through elevator spar and threaded cable using safety wire attached to a pulling cable.
Drilled holes in pitch push/pull tube and attached elevator yoke.Attached both elevators. Set pitch trim aft/forward stops with pop rivets on push/pull tube.
