Found general guidance for attaching wings on the Rans Clan forum (thank you). Used a spacer tube to guide drill bit through leading edge spar, removed it, then redrilled with larger bit to correct size. Filed down T fitting on fuselage, then fit on the wing.
Sounds simple, but takes some thinking and prep work to get it right.
