Bills Web Site
Date:  8-6-2012
Number of Hours:  6.00
Brief Description:  Brake fluid
Hooked up brake lines to each tire, then attempted to fill the brake lilnes with fluid bottom uip, but it didn't work. Called Bobbi, who came over with a proper fill can and filled the lines from the top,
This procedure took a long time, with much effort on everyone's part, pumping the brake pedals and making a mess. The brake pedals are no longer soft, but there is still air in the lines.
Brake line attach to left wheel
Bobbi adding fluid
Bobbi adding fluid
Filled brake lines
Filled brake lines
