Wet sanded upper wing surface with 1500 grit. Buffed wing upper surface with power buffer. Re-inserted wiring through wing conduit. Crimped new connectors onto navlight and strobe wires at wingtip end. Rebuilt nav/strobe assembly with new green lens, new nav bulb, new tail bulb, new strobe tube and new gaskets. Attached nav/strobe assembly to wingtip. Attached right wing to aircraft. Torqued all attach bolts. Reconnected fuel lines made of new Mil 6000. Reconnected nav/strobe wires in cockpit. Reconnected aileron push rod. Reconnected fuel quantity probe wires. Reconnected fuel float switch wires. Spliced AOA tubes together with connector.
