Re-assembled all door mechanism and lock. Mounted door on fuselage with 16 new machine screws and nuts.
Added nust to remaining 2 elevator hinges and torqued (this was a 3 hour project due to the extremely small clearances and difficulty getting nuts started. With 2 ignition wrenches made a 1/32 turn, removed and reversed one wrench, made another 1/32 turn, etc).
Assembled bolts and nuts through center elevator hinge/control arm assembly. Installed center and aft elevator push rods.
