Drilled alignment tabs for clecos. Trimmed tank top to size. Ground flat side on AN970 washers on inboard chair rail stop, flat side down. Installed seats. Cut grooves in tank top for seat rail stops.
As seats are moved aft, the inboard seat rails descend slightly below the level of the tank top. A tube will be used as a mold to make room for this.
