Sanded yesterdays layups. Drilled 3/16" holes through the hard points installed yesterday. Bonded nutplates that had previously been mounted on carbon plates to tank with flox. Made foam cover over nutplates. Glued cover to tank with superglue. Layed up 2 bid carbon over foam covers.
Did final sanding on tank interrior. Vacuumed tank and cleaned with acetone. Painted Jeffco fuel sealer into 2 tank compartments.
Went to Refinish Solutions and purchased PPG Concept paint, reducer, hardner, tack cloths, etc for painting baffling.
