Repainted the area of the rudder counterweight where I drilled and added lead.
Drilled and tapped for AN3 bolts for forward gear door spring mounts.
Wired 3 position connector on cabin door frame. Ran wires through previously imbeded tube down to lower left fuselage side. Added and tied off 12 volt wires for possible future lighting in overhead.
