Made new mounting base for hydraulic manifold. Base constructed yesterday cured with the studs at an angle. Could not be fixed. Today, allowed flox to cure while attached to the manifold to insure proper stud alignment.
Made 2 spacers to hold pump bulkhead away from fuselage side. Filled cored aft edge of bulkhead with epoxy flox. Attached bulkhead to wheel well bulkhead and to fuselage side.
