Fabricated carbon bracket to attach to side of radio rack supports. This will mate with a bracket to be constructed on header tank to stabilize the instrument panel.
Mounted nutplates to fwd side of panel attach brackets.
Fabricated small shelf and retainer bracket for avionics sub panel. The sub panel holds ARINC box, GRT-GPS and WX receiver. Attached bracket to aft side of firewall fwd of avionics stack.
Removed boost pump. Ground out clearance for pump drain on outboard side.
