New set of rudder bars arrived from Lancair. Cut both sets of right rudder pedals off. Cut both sets of right brake attachment off. Filed all cuts, painted all raw surfaces with flat black paint. This set of rudder bars will be for the single place version of the airplane. Rudders removed to make room for fuel tank in passenger footwell area.
Made airfoil shaped standoff for HF antenna. Brass rod is the conductor. Nylaflow tubing passes through both standoff and interrior block to act as insulator. Trailing wire HF antenna will connect to standoff with forked connector
