Added 2 bid carbon layup to fwd aileron torque tube phenolic support. Covered full aft face and 1" minimum on fuselage sides. Added 2 bid carbon to fwd face between firewall support, fuselage and phenolic.
Enlarged holes in fuselage and ribs for flap push rods going to center flap bellcrank on gear box. Made temp rods from scrap to check movement, length and clearances.
Added additional wing fillet standoff rib just fwd of existing rib. Existing rib interferred with push rod. Will remove origional riib tomorrow.
