Hysoled "pyramid" phenolic spacers to fwd and aft torque tube supports. Microed right fwd support to fuselage. Attached right aft torque tube bearing to support. Ground slot into spar load layups. Placing the bearing at the location called out in the manual causes interferrence with fuselage side (picture 3). Will need to grind honeycomb in interferrence area and layup additional carbon.
