Layed up 1 bid carbon over previously cut slot below pin receiver. Applied micro over flox at cowling pin receiver area.
Aft baggage bulkhead slot for air hose needed to be moved right due to interferrence with GPS antenna behind bulkhead. Cut new slot on right side and added material to left. Once cured, proper slot will be cut in the new material.
