Layed up 2 bid carbon spanning 1" minimum on PVC to 1" minimum on cowling.
Finished masking fuselage interrior. Sprayed zolatone on area of upper/lower fuselage joint. Sprayed zolatone in aft baggage area at fuselage / tail joint. Sprayed zolatone around cabin door and other touch up areas.
