Ground taper in 2" section of 4" PVC pipe. Used this small section to lock LED landing light into mount. Will drill for 2 4-40 machine screws to lock pipe in place.
Sanded plexiglass lens outside of bulb area. Sanded PVC pipe. Tacked PVC to lens with 3 small sections of duct tape. Applied epoxy/flox to perimeter of PVC/lens intersection.
Traced landing light on cowling. Cut approximately 1" outside of bulb area to allow for bodyworking lens into cowling. Cut hole in cowling. Drilled holes in plexiglass and cowling for clecos.
Aimed landing light 10 degrees down and 3 degrees left. Published beam width is 10 degrees.
