Sanded carbon tape at upper/lower fuselage halfs in preperation for micro. Worked on cabin door fit. Sanded and trimmed fwd edge of door.
Fit nylon striker blocks for baggage door. Installed blocks with flox and 3 bid carbon tape.
Go two longer lock levers from Gary Schue. These levers only have one hole each where the shorter ones had one horizontal and one vertical hole. Machined a new square hole in one of the levers for use on the forward baggage lock.
