Opened up holes in outer baggage door skin to slightly larger than lock face. Covered lock faces with plastic tape. Waxed lock bodys. Spread micro in lock holes through phenolic lock base and outer skin. Pressed lock into lock base, clamped lock to door. Turned mounting nut to slowly lower lock body into hole till lock faces were flush with door outer surface. Allowed to cure.
After cure, removed locks and sanded mocro flush with door surface. Re-installed locks...perfect flush fit. Still need to make a spacer washer for lock shaft.
