Cut flange layup so as to leave just a border around the door opening . Pressed micro into the kerf between the door and opening. Allowed to cure about 50 minutes. Cut new kerf in soft micro with an exacto knife. After sanding this will produce a very thin kerf around the door.
Patched cleco holes around left aft window with micro. Patched cleco holes in exhaust fairing with micro.
