Drilled #60 holes in rudder trim tab hinge for safety wire. Microed elevator trim tab push rod fairing. Applied Evercoat body putty to scratches, pinholes, etc. Sanded evercoat. Thorough vacuuming of empennage. Used compressed air to blow any remaining dust. Wiped down with acetone. Applied 3 coats of PolyFiber SmoothPrime with foam squeegee. Cut kerfs for inspection panels in SmoothPrime
