Adjusted cradle to better clamp ribs. Removed wood from left wing leading edge (clamp points) and installed on right wing. Cut rubber strips to go between upper cradles and wing skin. Performed full dry run with all clamps and shot bags. 24 hours on the pressure test of left wing. Tests OK.
